Forums >> Revit Building >> Technical Support >> Sloping & angled walls
Fri, Oct 1, 2004 at 2:12:50 AM | Sloping & angled walls
Irish
Farely new to Revit 6.1. Know ADT 2004. Wanting to know how to create walls that both slope and angulate.
Fri, Oct 1, 2004 at 2:46:21 AM | RE: Sloping & angled walls
ale02
ale02 Avatar
3 Stars: 3 Votes
As far as i know, for sloping wall, you have to create in place or create family for it. you mean sloping and angulate, did you mean cone shapes or irregular shapes? if cone shapes probably you can try to create using solid>revolve (for full cone shape), If for half-cone or irregular shapes, I think solid> blend or solid> revolve to create a full cone and void> extrude to hide the side you want to hide. Hope it can create what you want coz I am pretty new to revit as well.
Fri, Oct 1, 2004 at 2:55:46 AM | RE: Sloping & angled walls
Irish
thank you for that. And we have two of us in our office at the end of the work day on Friday trying to figure this out. What I am trying to create are flat sloping walls that have differing top & bottom dimensions.
Fri, Oct 1, 2004 at 4:35:15 AM | RE: Sloping & angled walls
hjin
I think the best tool to use here is solid>blend, if you are just doing sloping flat wall with same top & bottom dimension, solid> extrude will be just nice, you just have to rotate to the slope you want once you finish extrude. Haha, enjoy your Friday, Irish. I am off now. guess you should be at home by now, right? nvm, you can get to this reply on next Monday.
Wed, Oct 6, 2004 at 10:28:00 PM | RE: Sloping & angled walls
Rythmick
5 Stars: 2 Votes
Farely new also and maybe I'm not understanding the question, but if your looking to angle the sides and slope the top plate why wouldn't you just create the walls to your bottom dims, select the wall and edit the profile? If your looking to slope the walls out of plumb then perhaps you should construct your walls with a roof.
Thu, Oct 7, 2004 at 8:26:10 PM | RE: Sloping & angled walls
Rythmick
5 Stars: 2 Votes
Irish, did you check out this Thread: arc slanted curtain wall
Thu, Oct 7, 2004 at 10:54:37 PM | RE: Sloping & angled walls
Irish
I did, thank you. After the last week of persistance - we may have resolved this one.. Thanks all
Fri, Oct 8, 2004 at 12:37:27 AM | RE: Sloping & angled walls
ale02
ale02 Avatar
3 Stars: 3 Votes
Sorry, it is my mistake to make the simple subject seems so difficult. Rythmick's idea is correct for the slope & angled walls. edit wall will do. Arc slanted curtain wall? is it related to ruled curtain wall?
Angled Walls in Revit
Mon, Jan 12, 2015 at 8:48:26 AM
Angled Curtain Walls - Not Sloping Glazing
Wed, Apr 22, 2009 at 3:20:31 AM
Sloping / inclined / leaning walls - any way to do these now?
Fri, Aug 28, 2009 at 12:30:02 PM
Making Angled or canted walls
Tue, Jun 3, 2008 at 2:10:07 PM
Sloping walls meeting a sloped roof
Fri, Aug 5, 2005 at 3:08:52 AM
Page generation time: 0.3312
