Forums >> Revit Building >> Technical Support >> Solar Gain and Windows
Mon, Aug 14, 2006 at 9:02:38 AM | Solar Gain and Windows
colonel022
I would like to study the Solar Gain in Section. Yet the window is blocking the light. Is there a way to edit my family so the glazing is more translucent. Or should I just erase the window for now.
Wed, Aug 16, 2006 at 11:36:09 AM | RE: Solar Gain and Windows
jfurlong
you can edit the material the the glass is made by. or edit the family and delete the glass.
Wed, Nov 22, 2006 at 12:29:39 PM | Solar Gain and Windows
formfunction
2 Stars: 4 Votes
Neither of these ideas you had worked.
Sat, Mar 10, 2007 at 8:12:43 PM | Solar Gain and Windows
dRad
in the rendering design bar there is an 'daylights' option.  you can use this to select windows or transparent surfaces that will allow light to pass through...i know that this option works in a render but not sure about the section.
Adding the solar heat gain coefficient to glass doors?
Mon, Dec 16, 2013 at 5:08:27 AM
INTERIOR SOLAR STUDIES [ 1 2 ]
Wed, Oct 8, 2014 at 4:42:37 AM
24
Solar Study Animations
Mon, Jan 19, 2026 at 1:09:00 PM
Animated Solar Studies in Revit 9
Tue, May 26, 2009 at 1:00:58 PM
Solar study
Fri, Mar 13, 2009 at 11:59:45 AM
Page generation time: 0.8311
