17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Wall that follows the floor level/surface
4 Posts No Rating |
Sirs...I'm using revit to do a small park and I come across this problem....any advice would be very much appreciated.
I have some funny curved shaped planter walls that has to follow the various level of the ground...and most difficult part is...the ramp...can anybody out there kind enough to help me on this please...Many Thanks!
I attached herewith the plan...
Ronnie
have you tried to use the "edit profile" option for walls
select the wall
up on the properties bar select edit profile.
if this doesn't work let me know and also post a 3d image of what you are trying to achive.
Have you tried to "ATTACH" the wall to the ground and ramp? Highlight the wall in question then select "ATTACH" in the option bar, then select the ground, sidwalk, or ramp that is below it.
Hope this helps
ArchWestCY
Edit profile will work but only as a vertical wall. That is that all of the wall elements remain vertical - not parallel with the sloping surface. Although it is rare, there are occasions where you may want the wall to run parallel and edit profile won't do that. We need to be able to rotate the surface pattern off the x-y axis.
You might also try creating an inplace void fmaily and use cut geometry to match the slopes and it needs to be off axis as WWHub was suggesting.
create a filter for floor surface patterns below |
Mon, Dec 3, 2018 at 6:51:01 AM
floor and wall joining and finish material |
Fri, Oct 25, 2013 at 1:35:18 PM
Surface Pattern on Modified Floor - No Skewing for Floor Plans |
Mon, Sep 12, 2016 at 7:45:11 PM
Site Elevation to Floor Level Problem |
Wed, Jun 27, 2012 at 11:42:30 AM
Light not placed on the surface of one wall but is on the surface of another?!? |
Mon, Sep 17, 2012 at 7:26:20 AM
