Forums >> Revit Building >> Technical Support >> Project
Sun, Aug 13, 2006 at 5:38:09 AM | Project
janlom
Hi there I am a new Revit User While going throught the revit house kit the presenter mentioned that the lesson project can be used as a template for future house projects. The problem is that the project was done using imperial format whereby I want it to be metric. Does anyone have a metric pemplate or can I convert the lesson template? Regards Jan
Sun, Aug 13, 2006 at 1:06:05 PM | RE: Project
lpromana
4 Stars: 2 Votes
When you install the software it gives you the oportunity to install all the metric templates and metric tutorials, the template that you are looking for should be there. When you go to start a new project browse to the template files folder and go up one level if you installed your metric files they should be right there, good luck Smile
Mirror Project - Revit Architecture 2013
Sat, Jan 25, 2014 at 5:41:31 AM
project standards
Wed, Feb 1, 2012 at 11:18:52 AM
Cannot Edit Label After Inserting into Project
Fri, Sep 14, 2012 at 7:07:14 PM
Having more than one project north within a project?
Fri, Mar 26, 2010 at 7:05:09 AM
Revit Architecture 2013 - Track time for project or history of project
Mon, Nov 4, 2013 at 2:09:27 PM
Page generation time: 0.7924
