Forums >> Revit Building >> Technical Support >> Typical Floor as a Linked Revit File
Thu, Aug 10, 2006 at 6:11:25 PM | Typical Floor as a Linked Revit File
gavinberman
We are building a condo with 5 instances of a typical floor plan. After dealing with much frustration always having to copy and past the floors up we have tried to create a seperate revit linked file for the typical floor. The idea in theory works great, enabling easy updating of the entire exterior and interior of the typical plan. The problem arises though, when trying to underlay the typical plan in other views. Is it possible to get the linked file to display in the underlay? Does anyone have any suggestions or any other methods of increased productivity when dealing with a typical floor. Thanks guys Gavin
Thu, Aug 10, 2006 at 6:57:49 PM | RE: Typical Floor as a Linked Revit File
Steve_Stafford
5 Stars: 2 Votes
Some folks will make the first floor then group it, copy to clipboard then paste aligned to each other floor. Changes to one will change them all. I really like using massing. I sketch a mass object that represent slab edge. Then make the mass taller than my highest floor. Finish mass, then select it, use Floor Area Faces on the options bar to assign a floor area face to each level. Then use Floor by Face to assign a floor to each face. If the slab edge needs to change I change the mass and then remake the floors via the Remake option. Do the massing tutorials to get a better sense of it perhaps. Then to manage the penetrations take a look at Modelling > Opening > Create Shaft Opening. These buggers can cut any floors, ceilings and roofs that it comes into contact with managing your vertical penetrations with one object for the full height of the building if necessary. Post edited on 2006-08-10 18:58:12
Thu, Aug 10, 2006 at 6:59:41 PM | RE: Typical Floor as a Linked Revit File
Steve_Stafford
5 Stars: 2 Votes
This is a building made of massing and floors by face. The massing can make short work of undulating or leaning buildings slab edges.
Fri, Aug 11, 2006 at 10:35:25 AM | RE: Typical Floor as a Linked Revit File
gavinberman
Appreciate the help steve. I like that mass too, but thats not exactly what I mean. I am past the massing stage of development. All interir walls are already deaigned, so I need to think beyond just the floor slabs. I have used groups on another project and have descided they are way to much of a pain. That being said, does anyone know if you can underlay a linked file? Thanks Gavin
How to swicth between levels with a linked revit file
Thu, Feb 18, 2010 at 7:43:39 AM
Spot Elevation for a typical floor
Wed, Aug 9, 2017 at 8:16:05 PM
Typical floors
Thu, Sep 28, 2017 at 1:41:12 PM
revit freezing and not responding when cad file linked
Fri, Feb 6, 2015 at 11:24:56 AM
Typical Floor Plan
Fri, May 8, 2015 at 8:51:28 AM
Page generation time: 1.6686
