Forums >> Revit Building >> Technical Support >> ADDING PATTERNS
Thu, Aug 10, 2006 at 3:50:09 PM | ADDING PATTERNS
moxierawk
I DOWNLOADED SOME PATTERNS BUT YET SMOE DON'T WORK WITHOUT A DRAFTING AND SOME DO. hOWEVER ANOTHER ISSUE IS THAT THEY DON'T SHOW A PREVIEW WHERE OTHERS DO. DOES ANYONE KNOW WHAT IS UP WITH THIS ISSUE OR WHAT I AM DOING WRONG OR NEED TO DO. THANKS.
Thu, Aug 10, 2006 at 9:18:14 PM | RE: ADDING PATTERNS
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Patterns that don't display are either too coarse or too dense to display in the preview. Adjust the Scale to have these display (you have to click on the name of the Pattern before the scale becomes active). Patterns are either drafting or model patterns. To specify what you want edit the PAT file in Notepad and add a ;%TYPE=DRAFTING or ;%TYPE=MODEL value at the begining you
Fri, Aug 11, 2006 at 8:09:01 AM | RE: ADDING PATTERNS
moxierawk
thanks
adding patterns to Revit
Fri, Apr 16, 2004 at 4:12:31 AM
The ability of adding text or symbols into line patterns
Thu, Oct 30, 2014 at 2:45:39 AM
Wall sweep, adding horizontal patterns
Sat, Apr 5, 2008 at 1:23:38 AM
Where do model patterns go?
Thu, Sep 24, 2015 at 9:37:41 PM
Material cut patterns
Mon, Sep 19, 2016 at 8:56:36 PM
Page generation time: 0.3538
