Forums >> Revit Building >> Technical Support >> Surface patterns too dense in oblique views
Wed, Aug 9, 2006 at 9:36:14 PM | Surface patterns too dense in oblique views
psymon
psymon Avatar
3.5 Stars: 6 Votes
We have a problem where the building we are working on has several walls that are at an angle only a few degrees off to the elevation view. The result is that the surface pattern for the roof and walls prints almost black as it is so dense. This wall looks o.k. when seen from the other elevation (which is almost perpendicular to the view). Is there any way to fix this? We don't want to turn off the surface pattern in the elevation as the other walls (which are perpendicular to the view) appear correctly. We don't want to assign a different material to the problem wall either as they will appear different in the other views. Any suggestions?
imported acad hatch patterns
Sun, Nov 25, 2007 at 6:39:02 PM
No Surface Patterns in Perspective
Thu, Feb 1, 2007 at 4:55:53 PM
Oblique Symbolic lines
Thu, Jan 1, 2015 at 3:47:42 PM
The pattern with the values specified is too dense/too large
Fri, Aug 3, 2012 at 8:37:21 PM
Fri, Jan 27, 2012 at 7:04:34 AM
Page generation time: 1.1319
