10 Users Online (8 Members):
Forums >> Revit Building >> Technical Support >> Importing .dwg Details - Model Space vs. Paper Space
I am trying to import some autocad details into Revit. The details are drawn in model space and the text/dimensions are in paper space. When i pull them into revit i only get the paper space info. (if i delete all of the paper space info, the model space linework imports, but at full size) Is there a way to bring everything in together with the proper relative size?
Thanks-
Unfortunately Revit can't calculate for bad drafting. As you've stated the text and dimension in paper space are drawn at a different scale and revit can't calculate for both.
The only thing i can suggest is try importing the dwg into a sheet as opposed to a view and see if this works.
Importing Paper Space/Model Space from CAD File |
Mon, Nov 17, 2014 at 9:46:02 AM
Inner space is not surrounded by outer space with higher height. |
Thu, Sep 6, 2012 at 8:34:57 AM
CAD files importing with huge blank space [ 1 2 ] |
Fri, Sep 3, 2010 at 11:43:39 PM
16
DWG sheets to RVT |
Sun, Jun 9, 2019 at 10:57:52 PM
Managed links -Autocad paper space |
Thu, Mar 8, 2018 at 8:21:28 AM
