Forums >> Revit Building >> Technical Support >> Pella Windows visibility problems
Wed, Aug 9, 2006 at 4:03:02 PM | Pella Windows visibility problems
Manarch
3 Stars: 4 Votes
I downloaded the Pella windows family but can't use them because they are not visible in plan view, they are only visible in 3d and elevation view. I tried fifferent VG trick , but no resolts. any help?
Wed, Aug 9, 2006 at 4:50:16 PM | RE: Pella Windows visibility problems
TomDorner
4.5 Stars: 25 Votes
It showed up in plan view for me. Make sure that your view has the window category displayed and that your cut plane is cutting through the window. To set cut plane go to View Properties (VP) then scroll down to view range and set accordingly. If your window is above the cut plane such as in a stairwell high bay, then you may want to explore "plan regions" which set the cut plane differently for a certain area of the view. HTH Tom
Wed, Aug 9, 2006 at 5:09:01 PM | RE: Pella Windows visibility problems
archdan
3.5 Stars: 2 Votes
Looking at the family there seems to be something wrong with the modeling of the geometry. I can't quickly pinpoint what it is but it is causing the cut geometry to be shown in projection instead of as cut. The quickest work-around for this would be to make all the modelled geometry not visible in plan view and draw symbolic lines (locked to the existing modelled geometry) which will accurately show the window in plan. The only other work around I can think of is to try playing aournd with plan regions and see if you can get most of the geometry above the cutting plane and above the view range limits. HTH. The reason why the changing the visibility (VG) settings didn't work was that none of the gemometries were connected with the subcatergories for the window. Post edited on 2006-08-09 17:10:09
Wed, Aug 9, 2006 at 5:50:19 PM | RE: Pella Windows visibility problems
TomDorner
4.5 Stars: 25 Votes
Again, lack of properly created content is rearing its ugly head. I've said this so many times yet it seems to be falling on deaf ears at Autodesk. As more people are adopting Revit this is going to become a worse problem not better and I'm afraid it will sink the mass adoption of Revit if Autodesk doesn't get with it. Tom
Pella and other Windows
Fri, Nov 12, 2004 at 3:14:52 PM
Pella Designer Series window model
Mon, Apr 20, 2015 at 3:29:36 PM
Pella window - I modified the download and want to change to fixed
Wed, Mar 14, 2007 at 8:57:02 AM
Pella Window Head Height Schedule Problem
Mon, Mar 12, 2007 at 5:42:21 PM
Graphic problems while in 3D Realistic view in 2013
Tue, Sep 25, 2012 at 4:10:41 PM
Page generation time: 1.7483
