Forums >> Revit Building >> Technical Support >> auditorium seats lack elevation adjustment
Thu, Sep 30, 2004 at 4:21:58 AM | auditorium seats lack elevation adjustment
ekarak
5 Stars: 2 Votes
is there a way to 'elevate' revit's metric library auditorium seats? they seem to be missing the "elevation" attribute...
Thu, Sep 30, 2004 at 5:18:26 PM | RE: auditorium seats lack elevation adjustment
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I can't say i've ever used them. But i suppose two possible solutions would be to place reference planes in elevations at each level you want to place them and then set each one sequentially as the work plane and place the seats. Other method is to nest the family into another (new family) and add a parameter for the elevation...
Thu, Sep 30, 2004 at 5:52:42 PM | RE: auditorium seats lack elevation adjustment
Mr GG
3.5 Stars: 9 Votes
Why not use a floor with a slope arrow? And the seats will adjust themselves then you place them on the slooping floor. Have a look at the image...
Thu, Sep 30, 2004 at 6:12:57 PM | RE: auditorium seats lack elevation adjustment
Mr GG
3.5 Stars: 9 Votes
You can have a look in the Family Explorer for Mr GG:s metric cinema seat. Here is an image showing how to use them. so it will be a little easier for the public to climb the slope...
Fri, Oct 1, 2004 at 1:36:09 AM | RE: auditorium seats lack elevation adjustment
ekarak
5 Stars: 2 Votes
for beginings, thank you mr Spot, mr GG for your replies! I don't want to build a sloped floor, just a small 2-level auditorium in a 60m2 rectangular area (no room for slopes!)... I'll try adding a hidden sloped floor to host the seats and on top the two riser levels, and see what happens I attach a trial rendering of the auditorium, check it out!
Fri, Jul 22, 2005 at 10:26:42 AM | RE: auditorium seats lack elevation adjustment
angelo
orea doulia
Sat, Jul 23, 2005 at 11:07:09 PM | RE: auditorium seats lack elevation adjustment
meelio
2 Stars: 3 Votes
Based on the size of that room, I'd suggest using work planes - a sloped floor never seems to work particularly accurately.
auditorium seats lack elevation adjustment...
Thu, Sep 30, 2004 at 4:19:22 AM
Move Portion of Project to New Levels
Wed, Jan 7, 2015 at 1:59:25 PM
Auditorium Seating
Wed, Sep 8, 2010 at 7:07:56 AM
Joist Seats of Unequal Depths
Thu, Jun 12, 2008 at 9:19:49 AM
Excavating for a theater auditorium
Thu, May 24, 2007 at 9:09:23 AM
Page generation time: 0.2397
