Forums >> Revit Building >> Technical Support >> Making a demolished wall transparent
Wed, Aug 9, 2006 at 6:54:00 AM | Making a demolished wall transparent
cadjockey
Hi all, Is it possible to make a wall that has been marked as 'Demolished' (you have used the demolished tool on it) transparent in your elevation andsection views? cadjockey
Mon, Apr 16, 2007 at 10:44:26 PM | Making a demolished wall transparent
dvsbob
TO MAKE A DEMOLISHED WALL TRANSPERANT GO TO PHASES UNDER SETTINGS, THEN GRAPHIC OVERIDES. THEN GO TO 'MATERIAL' FOR THE DEMOLISHED PHASE AND GIVE IT A COLOUR AND U CAN MODIFY ITS TRANSPERANCY.
REGARDS,
DVSBOB
Tue, Aug 1, 2017 at 12:40:58 PM | Making a demolished wall transparent
adanedhel
4 Stars: 3 Votes
it doesnt give transparency in floor view or section view only in perspective views....
Mon, Jan 24, 2022 at 6:22:30 PM | Making a demolished wall transparent
vondoran
SOLUTION-
Go to Manage Tab > Phases > Graphic Overrides tab > change cut patterns to hidden / not visible
Then-
Go to view properties >
Visibility / Graphics > (or view template already applied to view)
Filters >
Create a new filter for walls, name it; Wall Demolished, Under Category tick Walls, Under Filter Rules; Select Phase Demolished, equals & new construction.
Add the new filter to the view / view template
highlight the Walls Demo filter in the list, check enable filter and visibility, CHANGE TRANSPARENCY TO 100%
RESULT in Revit 2022 = the outlines of the walls are shown but the core is now transparent.
I assume this works for previous revit versions too.
MAKING DEMOLISHED OBJECTS TRANSPARENT
Tue, Mar 12, 2013 at 2:02:34 PM
DEMOLISHED PHASE
Tue, Jan 16, 2007 at 10:58:45 PM
Transparent Demolished
Fri, Aug 25, 2006 at 3:45:35 AM
Demolished walls overlap furniture in plan.
Mon, Nov 26, 2012 at 1:08:02 PM
Schedule or quantity for just demolished walls
Wed, Sep 19, 2012 at 1:16:22 PM
Page generation time: 1.1781
