Forums >> General Discussion >> Wishlist >> batt insulation fill pattern (drafting)
Tue, Aug 8, 2006 at 1:24:09 PM | batt insulation fill pattern (drafting)
wataeli
5 Stars: 3 Votes
I found an insulation fill pattern which was a model type, but I need a drafting type. When I changed it to drafting on the txt document, it lost its pattern. Does anyone know how to convert a model type pattern to a drafting type? Or has anyone already created a drafting insulation fill pattern? I'd appreciate any help.
Tue, Aug 8, 2006 at 2:48:07 PM | RE: batt insulation fill pattern (drafting)
TomDorner
4.5 Stars: 25 Votes
Is there a reason yu do not want to use the built-in Revit batt insulation tool found on the Drafting tab?
Tue, Aug 8, 2006 at 2:57:01 PM | RE: batt insulation fill pattern (drafting)
wataeli
5 Stars: 3 Votes
Thanks for the quick reply. I am trying to create a new material which would be a metal stud with batt insulation. In order for this to show in the section, I have to create a fill pattern (must be drafting type). If I can create a wall family that already has the insulation within the studs, I can avoid having to draw in the insulation at every section cut. It should appear automatically (like CMU or rigid insulation) if I can create a .pat file for it.
Tue, Aug 8, 2006 at 3:46:27 PM | RE: batt insulation fill pattern (drafting)
TomDorner
4.5 Stars: 25 Votes
In the AutoCAD world as I remember, batt insulation was accomplished using a LISP or Diesel routine using a series of bulge arcs. I don't have any batt insulation acad hatches, but you may try to find one or maybe someone on this site has one. Any ACAD or most CAD package hatches can be used in Revit by adding the proper header to the pattern (see Revit help file). HTH Tom
Tue, Aug 8, 2006 at 3:57:22 PM | RE: batt insulation fill pattern (drafting)
coreed
coreed Avatar
4 Stars: 16 Votes
in the autocad world, batt insulation is a linetype now. but you should be able run a hatch pattern generator on a sample of this and create a .pat file Post edited on 2006-08-08 15:59:55
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Thu, Nov 1, 2012 at 12:32:34 PM | batt insulation fill pattern (drafting)
imaginesociety
Has anyone found a solution for this? I am using Revit 2013 and there is no batt insulation hatch. There is a rigid insulation hatch, but no hatch for batt insulation. I have tried using various CAD .pat files but none of them have worked.
Thanks.
Thu, Nov 1, 2012 at 12:45:14 PM | batt insulation fill pattern (drafting)
Batt insulation has been around from the beginning.  Look on your detail tab.
Thu, Nov 1, 2012 at 12:57:12 PM | batt insulation fill pattern (drafting)
imaginesociety
What if I'm just trying to created a filled region with a batt insulation hatch?
Thu, Nov 1, 2012 at 1:03:19 PM | batt insulation fill pattern (drafting)
imaginesociety
Ahhhhh, now I see. Don't know how I've made it this far without seeing that curse tool. Thanks.
Wed, Nov 11, 2020 at 6:01:17 AM | WWHub
Thisoke44
Quoting WWHub from 2012-11-01 12:45:14
I am an idiot. Thank you so much for this.
Batt Insulation Blanket
Wed, Aug 27, 2008 at 12:39:31 PM
Batt Insulation
Fri, May 16, 2008 at 5:48:56 PM
Insulation in Families
Mon, Dec 8, 2008 at 2:50:57 PM
More batt insulation options
Fri, Nov 21, 2008 at 11:50:55 AM
Solid Drafting fill pattern
Tue, Jun 23, 2015 at 1:35:01 PM
Page generation time: 3.0113
