Forums >> Revit Building >> Technical Support >> Problem creating coping
Tue, Aug 8, 2006 at 8:34:31 AM | Problem creating coping
sweetiedarling
Hi all - I'm having some trouble creating coping using the in-place sweep. I've been creating sweeps from more complicated shapes, but for some reason when I try to use this particular profile, it keeps coming back with an error message. Thanks for any suggestions!
Fri, Aug 18, 2006 at 4:31:48 PM | RE: Problem creating coping
derxaj
3.5 Stars: 3 Votes
Hey...I don't know if you figured it out already but the problem with the profile that you posted was the location on the profile inside of the family. When creating profiles you have to be very carefull where the lines are actually drawn inside the file because the location inside of the family relates to where it is attatched to the model once its used. When I make a new profile I always go to an existing one, that I know works right and then draw it in the same location, keeping the top aligned so that I know where its going to pop into the file. I fixed the profile up for you....take a look, try it out and then compare the two and see if you kinda understand what the problem was. Let me know what you think and if you get it...profiles are kinda tricky.... :D Adam
Coping beams in a family
Tue, Mar 25, 2014 at 10:27:16 AM
Truss - coping frame members
Mon, Aug 16, 2010 at 5:51:35 AM
Finish Profile at Stone Coping [ 1 2 ]
Tue, Jul 29, 2008 at 1:20:47 PM
16
How can I radius my coping of steel beams?
Mon, Oct 25, 2010 at 5:02:18 PM
Diagonal End of Wall - Void + Cut Geometry not working
Thu, Aug 29, 2013 at 3:47:20 PM
Page generation time: 2.3148
