Forums >> Revit Building >> Technical Support >> Raytrace region
Mon, Aug 7, 2006 at 8:37:57 PM | Raytrace region
cadjockey
Hi, When you do a raytrace region or any raytrace for that matter, am I correct in saying that the information regarding the accurender settings you created for a particular material is stored in the accurender.mlib file which in turn is located in the Revit library Rendering Accurender support file location. This path is of course set within the options settings of your project file. Does revit draw it's information from anywhere else to perform the render? eg. C:Documents and SettingsAll UsersApplication DataAutodeskRevit Building 8.1Data cadjockey
Mon, Aug 7, 2006 at 10:38:10 PM | RE: Raytrace region
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
The mlib and plib files simply contain a catalogue of materials for accurender. These materials located in the library may also make use of jpg maps or alpha channels which are located in other files, typically in your rendering library. HTH.
Wed, Aug 9, 2006 at 6:50:40 AM | RE: Raytrace region
cadjockey
What does the 'Data' file located via the 'Application data' route on your C drive have to do with revit if everything you need is located within the library? ie. templates,elements and rendering jpegs. cadjockey
Wed, Aug 9, 2006 at 5:23:23 PM | RE: Raytrace region
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Well i don't even have a Data directory in that location, so it would only exist if you installed some of the library locally on your computer. All our libraries are located on a file server. The directories only need to be added for each location that you have mlib or plib files.
Raytrace and region raytrace not working!!?!
Sat, Oct 11, 2008 at 9:19:03 AM
RENDERING-region raytrace
Sun, Jan 16, 2005 at 5:49:29 PM
about raytrace
Wed, Sep 29, 2004 at 5:21:13 PM
Revit 2013 Raytrace
Fri, Jan 25, 2013 at 12:01:05 PM
Raytrace
Fri, Oct 19, 2007 at 8:03:10 AM
Page generation time: 0.1010
