16 Users Online (14 Members):
Forums >> Revit Building >> Technical Support >> Spot Elevations In Plan
I need to call out all of the spot elevations for my roof for Bottom of Deck, is there a way I can snap to bottom of deck right now it snaps to top of deck. I really just need to see all my B.O. Deck spot elevations in my roof plan. Any ideas?
I cheated and made a leader style with an arrow head to match my spot elevation symbol, then just put in the right numbers.
Thats what I have been doing as well, but I wanted them to be hosted so if changes are made I dont have to manually change thoes.
it should go to the bottom as well, if not, put a line where you want and spot elevation from the line...
HTH
Setting a manual height for Spot Elevations in plan |
Wed, May 27, 2015 at 8:03:11 AM
rotating spot elevations on plan |
Fri, Mar 6, 2015 at 12:14:14 PM
Revit refusing to use Spot Elevations |
Mon, Oct 14, 2013 at 3:47:54 PM
13
IS IT POSSIBLE TO SPOT ELEVATIONS OF A WALL IN A FLOOR PLAN? |
Tue, Jan 25, 2011 at 1:25:12 PM
Spot Elevations on curved walls with varying height |
Tue, May 3, 2011 at 5:26:46 AM
