14 Users Online (12 Members):
Forums >> Revit Building >> Technical Support >> Real shadows x Revits shadows
24 Posts No Rating |
As I needed to do a sun study, I decided to check the shadows performanced by Revit. I've drawn the real shadow of an object ( known dimensions and angle) and tried to reproduce it in Revit. But the measured real shadow didn't match Revit's shadow. Geographic cordinates are correct, date is correct. The time zone is not editable and even I choose Brasilia (GMT-3:00) the value always change to Groenland.
Revit shadows should match the real ones?
What shoul I try to produce reliable shadows?
I wonder what method you used to producre the "real" shadow?
you can't edit the time zone but you can add your excact location by editing the UnicodeENU file normally under:
C rogram FilesAutodesk Revit Building 9ProgramAr3RedistUnicodeENU and adding your location (that's how i added Brisbane that for some reason Autodesk does not think is a city in Australia...)
shadows |
Mon, Apr 18, 2005 at 2:55:11 AM
Getting rid of shadows in Revit rendering? |
Sun, Dec 3, 2017 at 2:06:46 AM
Shadows Inverted- light is gray/shadows are white |
Fri, Sep 25, 2009 at 4:46:09 AM
Help with shadows |
Wed, May 28, 2008 at 7:00:59 AM
graphics for shadows |
Thu, Sep 6, 2012 at 10:46:58 PM
