Forums >> Revit Building >> Technical Support >> Revit vs construction management
Sun, Aug 6, 2006 at 8:37:55 PM | Revit vs construction management
ale02
ale02 Avatar
3 Stars: 3 Votes
Quote from http://www.aecbytes.com/buildingthefuture/2006/BIM_Awards.html "Graphisoft Estimator was used for the customization of cost and scheduling data, while Graphisoft Constructor was used to generate a fully-coordinated construction schedule by directly referencing portions of the architectural model and linking them to construction activities." Do revit have any built-in or API similar to Graphisoft Constructor?
Life is never easy but nor it should be complex. Just stay simple Smile
Thu, Feb 28, 2008 at 2:36:39 PM | Revit vs construction management
CBJConstruction
If you link Revit with Navis Works, Navis works has the ability to do this with is Timelinker program
Thu, Feb 28, 2008 at 2:43:04 PM | Revit vs construction management
coreed
coreed Avatar
4 Stars: 16 Votes
also Autodesk has aquired Navis Works, so i'm sure in the future these two-programs will work hand-in-hand.
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Does Revit support Facility Management?
Mon, Dec 4, 2006 at 10:18:50 PM
Traffic management
Thu, Apr 7, 2011 at 5:54:01 PM
Revit 2013 Model Review Management File
Fri, Mar 22, 2013 at 12:20:14 PM
best practice for construction notes in Revit
Mon, Mar 16, 2015 at 2:32:24 PM
Sheet and File Management Questions
Thu, May 28, 2009 at 10:34:10 AM
Page generation time: 7.0947
