Forums >> Revit Building >> Technical Support >> Archiving Details
Sun, Aug 6, 2006 at 8:08:47 PM | Archiving Details
dbruck
What strategies are you folks employing to archive standard details within the REVIT umbrella? For some reason, the importation of dwg details isn't a perfect endeavor. Some of the text gets a bit funky and sometimes the detail just doesn't look that good. I end up redoing dims and notes sometimes, sometimes stuff doesn't make it through the importation process. Its kind of a poor way to rely on detailing. I'd prefer to drop a REVIT based 2D detail onto a sheet, but from where? Where do I store such things? Also, if I utilize a part of the model geometry for use in a detail, I'd hate to have to recreate that detail in another project and have to add the same notes and same callouts and same dims all over again. Is there a way to store this stuff? A snapshot or a detail file analygous to a sort of mylar overlay where I could just drop the same notes onto the same detail whenever it occurs? Example: Jamb Detail typical notes and callouts for a particular door type where only the parametric aspects of the detail would then have to be edited. What are you folks doing to solve this problem?
Archiving Projects
Wed, Jan 9, 2008 at 1:25:45 PM
Archiving Projects
Mon, Oct 3, 2011 at 11:59:15 AM
how to reduce size of file for archiving
Tue, Oct 24, 2006 at 2:35:52 PM
Archiving Revit for Drawing issue.
Wed, Aug 13, 2008 at 11:44:42 AM
Archiving Projects
Thu, Feb 14, 2008 at 8:27:51 AM
Page generation time: 1.4306
