13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> 2x4 ceiling grid orientation
39 Posts No Rating |
I am having trouble controlling ceiling grid orientations in different sections of a reflected ceiling plan. Revit decides which way to orient the grid (horizontal or vertical). I have tried to change the orientation by creating a separate "material" for horizontal and vertical grids. But when I change one material to reorient the grid, the other grid changes orientation too. Any ideas?
Thanks,
dakota
When you place a ceiling Revit will put the grid in centered on the space, as close as it can. If you select a single grid line, you may have to tab to select it, you can use the move or rotate command to reposition the grid any way you'd like. This is true for Model Patterns, not for Drafting Patterns. Model patterns are what you should use for your material's surface pattern.
Thank you!
2x4 ACT CEILING DISPLAY ISSUES |
Tue, Dec 4, 2007 at 10:02:28 AM
Ceiling grid rotates when mirrored, lights fixtures don't. |
Tue, Dec 20, 2011 at 2:49:43 PM
Ceiling Grid Issues |
Wed, Jun 30, 2010 at 5:20:25 PM
Can you create your own Ceiling Grids?? |
Thu, Jan 5, 2017 at 8:44:31 AM
Ceiling Grids in Revit 2011 |
Fri, Jul 22, 2011 at 8:35:24 AM
