15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Cut patterns
Can someone point as to where the option is for changing how a cut pattern is read. I have seen it in the tutorials or help but can't locate it now. Have some 45 degress walls where the cut pattern is just a straight line.
Cheers
Macca Sunshine Coast QLD Australia |
1.Select the wall and click the properties bution in the options bar
2. Selct the Edit/New in the Element Properties Dialog
3.Select the Edit button next to Structure on the type Properties Dialog
4.In the structure row select cell under the materials column and you should a black down arrow appear, select it
5. To the right on the Apperance tab at the bottom you should see Cut Pattern. select the black down arrow to the right of it.
HTH
Thanks Coreed,
Its been stairing me in the face.
Cheers
Material cut patterns |
Mon, Sep 19, 2016 at 8:56:36 PM
Halftone cut Patterns |
Mon, Nov 19, 2012 at 4:05:25 PM
Section Cut Fill Patterns Black |
Thu, Dec 24, 2015 at 12:40:13 PM
Cut Pattern Issue |
Fri, Jul 2, 2010 at 3:30:55 PM
Wall cut patterns |
Fri, Jun 16, 2006 at 1:29:23 PM
