Forums >> Revit Building >> Technical Support >> Removing Components and Families
Fri, Aug 4, 2006 at 11:20:29 AM | Removing Components and Families
XxLarry007xX
I am working on a project for a renovaiton of a psychiatric center and I loaded a component by mistake. For some reason the file is bogging down my project. The file size jumped from 3.5 mb to 8 mb since it was loaded. Is there some way to remove it from the project like the purge command in autocad? any help will be aprreciated.
Fri, Aug 4, 2006 at 11:40:42 AM | RE: Removing Components and Families
TomDorner
4.5 Stars: 25 Votes
File>Purge Unused should work Tom
Fri, Aug 4, 2006 at 2:01:25 PM | RE: Removing Components and Families
krmccurdy
If you scroll down to the bottom of the project explorer, you can pick and choose individual families, too. Right click on a family then choose delete. This keeps from loosing, say, all the extra doors, windows, and door types you may want to keep that will be lost when you purge.
removing familes
Thu, Jan 30, 2014 at 1:30:28 PM
Edit Default Families
Sun, Jan 24, 2010 at 8:23:42 AM
Detail Components in System Families
Thu, Mar 27, 2008 at 12:56:03 PM
Furniture as detail components
Wed, Nov 9, 2011 at 5:30:43 PM
Rotating detail components in families
Mon, Nov 7, 2011 at 10:13:53 AM
Page generation time: 0.2791
