Forums >> Revit Building >> Technical Support >> New Regulation isues
Wed, Sep 29, 2004 at 11:05:16 AM | New Regulation isues
Jez
Hi i am the building cad designer for reed construction and i need to find out how to chang the way that the flanking walls join the party wall on a terrice block of houses. As you all will know we have to follow the Robust detail plan for Block and wet plaster or face a big payout to a sound enginer for testing. How can i acomplish this in revit
Wed, Sep 29, 2004 at 5:27:42 PM | RE: New Regulation isues
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
In the wall setup you can set each layer of the wall to different priorities. Priorities of the same level will trim together. Ie: Finish (4) or Finish (5) or Structure (1) or Substrate (2) or Thermal/Air Layer (3). A 4 layer and another 4 layer will trim to each other. If you have a wall with a 1 layer and another with a 1 layer and a 5 finish layer, the 1's will join to each other and the 5 inbetween will be cut out. I hope i made some sense anyways.
Thu, Sep 30, 2004 at 3:25:56 AM | RE: New Regulation isues
Jez
Thanks for your help Mr Spot Uk Building regulations are going mad
Changing wall finishing thickness without having to align it again
Tue, Jul 3, 2018 at 10:42:11 AM
Revit 2014 Update 2 crashes constantly on Nvidia Quadro FX 3800 cards
Tue, Jun 17, 2014 at 10:26:06 AM
Research project on the UK construction industry and BIM
Sun, Apr 21, 2013 at 10:38:56 PM
using views in other revit projects
Thu, Nov 11, 2010 at 8:22:00 AM
Managing multiple copies of a building section in the same project
Thu, Oct 24, 2013 at 2:58:56 AM
Page generation time: 2.6137
