Forums >> Revit Building >> Technical Support >> Grade Hatch in Elevation
Thu, Aug 3, 2006 at 4:45:32 PM | Grade Hatch in Elevation
badfish
Does anyone know how to, or if it's even possible to show only the Grade line rather than all of the Earth Hatching plus the grade line when you have a toposurface in your model?? I've been able to turn off the topo lines but not that pesky hatch
Wed, Apr 25, 2007 at 12:24:00 PM | Grade Hatch in Elevation
epeterson
I realize your post is from a year ago, but to turn off the hatch below the grade line go to settings>site settings... Choose the section cut material under section graphics and edit the cut pattern. Select no pattern in the lower left corner of the window. That should do it. Your elevations and sections will now no longer show the earth below.
Hope that helps.
-E
Mon, Aug 20, 2007 at 4:03:15 PM | Grade Hatch in Elevation
murfy17
I COUPLE MONTHS LATER AND IT IS STILL HELPING PEOPLE... ANSWERED MY QUESTION, THANKS!
Tue, Aug 5, 2008 at 10:06:38 PM | Grade Hatch in Elevation
schuss
Another year on, and still helping punters...
One step further...Now that I have the hatch switched off.  I can't see object beyond the cut plane.  I have extended the viewing parameter (green dashed line), but is all blocked out where the hatch used to be.
Tue, Aug 5, 2008 at 10:33:21 PM | Grade Hatch in Elevation
timbo89
timbo89 Avatar
4 Stars: 5 Votes
Im sure there is a better way, but you could right click the surface-->override graphics in view and select transparent. It will only be transparent in that view, so if you need to do it in many views, it may be annoying repeating that step. Is that what you wanted? Refer to picture
  • Core 2 Duo E8400 3ghz
  • 756mb Nvidia 9600GSO 256bit
  • 6gb Kingston RAM 800mz DDR2
  • Windows XP Service Pack 3 32-bit
Tue, Aug 5, 2008 at 11:05:45 PM | Grade Hatch in Elevation
schuss
timbo,  your image is exactly what I am looking at achieving, however I can't find 'transparent' anywhere...using Building 9 if that makes a difference. (also running on very little sleep too).
Tue, Aug 5, 2008 at 11:30:58 PM | Grade Hatch in Elevation
timbo89
timbo89 Avatar
4 Stars: 5 Votes
I have never used 9.1 so I don't know what features are available. Select the toposurface. right click on it, you should see a tab called "Override Graphics in View" and in that should be: "By element" "By Category" "By Filter". Select "By element" and another dialog box should come up, showing options to change projection line, surface etc. You then should see transparent up the top. If that doesnt work type "VG" and the visibility/graphics dialog box should show up, scroll down to topography and you should be able to see transparent in a column. I use RAC2009, so hopefully 9.1 has this option.
Tue, Aug 5, 2008 at 11:47:15 PM | Grade Hatch in Elevation
schuss
I've got the visibility/graphics dialog box, however there is no transparency option.
Tue, Aug 5, 2008 at 11:55:33 PM | Grade Hatch in Elevation
schuss
Wed, Aug 6, 2008 at 12:03:16 AM | Grade Hatch in Elevation
schuss
Grade Lines in Elevation view not showing
Fri, May 25, 2007 at 5:49:36 PM
invisibility below grade
Fri, Jun 29, 2007 at 9:38:06 AM
12
Control Hatch Display
Tue, Jan 10, 2012 at 10:26:34 AM
Wall finishes and grade
Tue, Aug 31, 2010 at 12:33:10 AM
differences between elevations
Wed, Dec 31, 2008 at 3:35:02 PM
Page generation time: 1.6900
