Forums >> Revit Building >> Technical Support >> misleading import of NURBS!!
Thu, Aug 3, 2006 at 12:02:11 PM | misleading import of NURBS!!
elvis
hi all, have a look a this site: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=5106083 under chapter Revit Building Maker it says: import NURBs and convert it into masses, anyone tried this? for example an double curved facade import as ACIS or IGEs and convert it into masses? if this was possible then the world would shiver over here Winking so far i have seen revit only can make simple solids and no double curved elements, like a sweep WITH a trajectory AND an profile consisting of a spline for example. even is you use a spline in revit you cannot close it, you have to implement a line to connect both ends. is there a way? vectorworks can do nurbs! grtz E
Wed, Oct 3, 2007 at 5:19:04 PM | misleading import of NURBS!!
elvis
ok in arch 2008, it's possible now,
but somehow the tesselation of the NURBS surface into a mesh in REVIT is so densed that my performance is being killed.
 is there a possibility to to change the tesselation?
NURBS import
Mon, Nov 28, 2005 at 10:33:40 AM
Nurbs Roof Import
Thu, Feb 16, 2006 at 2:32:58 PM
REVIT and NURBS
Sun, Mar 19, 2006 at 9:34:11 PM
Texture mapping for imported objects
Sat, Jul 29, 2017 at 9:33:53 AM
scan polymesh import to revit
Wed, Apr 9, 2008 at 11:34:10 AM
Page generation time: 4.8204
