12 Users Online (10 Members):
Forums >> Community >> The Studio >> separating arch. and struct elements in the same wall type
1 Posts No Rating |
If any one knows. When making a wall with finishes. Can I make the finishes non bearing and the structural wall part bearing so when you make a structural floor plan only the structural wall would be able to show. I tried it in a test and could not do it but maybe I am missing something? So far the only way I have done it is to make walls separate and then attach them to each other. The Problem is I work for an A&E firm and the architects that do the first drawings and don't care about the structural items. And then I have to go around and try to clean it up. It can take a wile to get that done and then making sure all opening and other items are accosiated.
1 Posts No Rating |
Try going into the properties of the wall and click on the edit new button. Under "construction" click edit and then where it says interior side click on insert and then you can move it up or down to either the exterior or interior face of the wall which will put your finish out side your core boundry. Then change the function of that line to a finish.
Post edited on 2006-08-10 15:34:59
We have >2K cols in proj. How can we replace our arch. elements 4 struct. ones |
Mon, Dec 12, 2011 at 4:05:12 AM
Problems Copying Walls from Linked Arch Plans? |
Wed, Jul 15, 2009 at 4:23:32 PM
Combinng sheets from Revit Arch, Struct and MEP into one CD set |
Mon, Apr 13, 2009 at 2:40:35 PM
Linking Arch file into Struct and using Arch groups? |
Tue, Jan 18, 2011 at 7:44:19 AM
Joining Cavity wall with separating wall |
Mon, Jul 14, 2014 at 9:12:31 PM
