Forums >> Revit Building >> Technical Support >> Wall Finish
Wed, Aug 2, 2006 at 4:52:10 PM | Wall Finish
derxaj
3.5 Stars: 3 Votes
Alright here's my issue....Does anyone know if it is possible to turn off the visibilty of a wall finish in plan? When we do drawings we never use to show exterior wall finishes on 1/8" plans, because all dimensions are taken to the face of sheathing or face of slab. We can still, of course, dimension to the core, but it gets alittle confusing for the consultants and contractors, who don't pay attention or read notes, when they see the extra lines for the exterior finish. Any suggestions?
Wed, Aug 2, 2006 at 10:31:27 PM | RE: Wall Finish
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
You could use the override host layers and make finish layers a white line so they are not visible in plan...
Mon, Aug 7, 2006 at 2:26:09 PM | RE: Wall Finish
derxaj
3.5 Stars: 3 Votes
Thanks for the idea but that really doesn't do it...you can only turn the inside cut lines to white, and if you turn off the visibilty of the cut pattern it is basically the same thing as setting the detail level to course. What I'm trying to do is eliminate the exterior finish line, while leaving the cut line for the core and leaving the interior finish line. I know...probably impossible....but...any other ideas?
Mon, Aug 7, 2006 at 5:44:08 PM | RE:
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
I don't think you looked in the correct settings.
Goto you visibility settings for that view-->where it says Override host layers down the bottom, hit edit.
Now you can set colours and linetypes for each individual layer of the wall. So you could change your finish layer there...
But that will the best you can do, other than creating the finish layers separately and then using filters to turn them off...
HTH.
Wed, Aug 9, 2006 at 7:54:48 AM | RE: Wall Finish
robert
will these settings also prevent dimensions snapping to the finish rather than to the core as they are supposed to do?
Wed, Aug 9, 2006 at 5:25:18 PM | RE: Wall Finish
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No. You can however set your dimensions to pick core faces as opposed to finish faces once in your dimension tool. However, it will still tab to finish layers.
Wed, Aug 9, 2006 at 6:02:51 PM | RE: Wall Finish
derxaj
3.5 Stars: 3 Votes
Wow thanks Mr. Spot....there are so many little buttons in Revit that I've yet to explore the full possiblities....expecially when it comes to visibility settings. Thanks alot!
Hiding finish line of wall in plan
Wed, Apr 1, 2015 at 7:04:50 AM
Applying Wall Finish and Scheduling It?
Fri, Jun 14, 2013 at 7:24:09 AM
Wrap wall finish to window ledge finish
Wed, Sep 21, 2011 at 2:57:36 PM
Wall Face finish
Sat, Jun 19, 2010 at 11:44:32 AM
Top Finish on Walls
Wed, Nov 29, 2017 at 1:55:05 PM
Page generation time: 4.3121
