Forums >> Community >> The Studio >> 3d max 8.0
Wed, Aug 2, 2006 at 3:10:36 PM | 3d max 8.0
timOthyj
4.5 Stars: 14 Votes
Okay I just picked up 3d max 8.0 and I was wondering from people who have used it, does Revit 8.1 do a easy transfer into that program or am I still going to have to take the drawings into ADT?
Wed, Aug 2, 2006 at 3:22:49 PM | RE: 3d max 8.0
coreed
coreed Avatar
4 Stars: 16 Votes
i think you are still going to have to export out of Revit to autocad or some other format and import into 3d Max
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Wed, Aug 2, 2006 at 4:17:37 PM | RE: 3d max 8.0
TomDorner
4.5 Stars: 25 Votes
Set up a 3D view in Revit then export that view to a .dwg file. In Max link that .dwg file in and be sure to use the Revit profile in the Max link manager. The materials asigned to object will come over in the .dwg metadata but you will have to assign them to a Max material. Light fixtures will come over, but not the light source so you will have to created those in Max. If you link the Revit export in then when the Revit file changes simply re-export and Max will pick up the changes. HTH Tom
Thu, Aug 3, 2006 at 2:13:09 AM | RE: 3d max 8.0
timOthyj
4.5 Stars: 14 Votes
Okay Autodesk...why oh why you sell the two same products make them mover easier to cross platform!!!! I mean $5000.00 for a software program isnt cheap..And why do you guys make it so difficult!
Thu, Aug 3, 2006 at 10:31:09 PM | RE: 3d max 8.0
Jaybo
4 Stars: 5 Votes
ok a few quik question whiles on the 3d max topic... 1. is viz render the same as 3d max if your just rendering or flybys and walkthroughs of a building?? 2. also can i put my revit design into 3d max or viz and create fly bys and walkthroughs?? any tips or discussion would be nice thanks as im looking for the best looking renders possible (photo realist) but have had not much experience with these programs but im willing to learn as my teacher is teaching viz. Id also like to know will a 2 gig of ram be powerful enough to do this??
Fri, Aug 4, 2006 at 1:52:55 AM | RE: 3d max 8.0
timOthyj
4.5 Stars: 14 Votes
3d max blows away viz... Its harder to learn..But the rewards are amazing.
Fri, Aug 4, 2006 at 1:54:45 AM | RE: 3d max 8.0
timOthyj
4.5 Stars: 14 Votes
....The only thing is that 3d max starts at around $5900.00 just for the basic program and then it has many I mean many architectural and real life materials that you can use..
Fri, Aug 4, 2006 at 2:00:30 AM | RE: 3d max 8.0
Jaybo
4 Stars: 5 Votes
ah ok cause i was told by my teacher that viz and 3d max are the same except viz is with out the animation stuff. so what is the best way to use 3d max with revit...will i need a powerful computer to use revit in 3d max
Fri, Aug 4, 2006 at 8:59:53 AM | RE: 3d max 8.0
timOthyj
4.5 Stars: 14 Votes
well of course any strong computer is good.. But any P4 and above will work..My next purchase is a dual processor, and dual video card.
Revit FBX causes 3DS Max to crash
Wed, Aug 10, 2016 at 6:02:27 PM
render my walkthrough in 3DS MAX
Tue, Apr 23, 2013 at 2:07:40 PM
Revit bring into 3ds Max [ 1 2 ]
Sat, Dec 25, 2010 at 6:24:33 PM
17
Revit to 3d Max FBX [ 1 2 ]
Wed, Dec 1, 2010 at 8:52:13 PM
17
Revit 2009 to FBX Import into MAX 9?
Wed, Jan 21, 2009 at 1:12:22 PM
Page generation time: 0.8088
