14 Users Online (12 Members):
Forums >> Revit Building >> Tips & Tricks >> CREATING A TOPOSURFACE EASILY
21 Posts No Rating |
IMPORT YOUR SITE PLAN IN AUTOCAD AND DRAW IT OUT AS YOU WOULD NORMALLY. tHEN GIVE EACH CONTOUR THE SPECIFIED Z HEIGHT IN 3D. YOU SHOULD HAVE YOU A STEPPED LINE LOOKING KIND OF LAND IN ACAD 3D. THEY SHOULD ALL BE CLOSED ALSO. THEN SAVE IT AS A DWG. IMPORT IT INTO REVIT. IT WILL BE FLAT. THEN GO TO TOPOSURFACE AND CLICK IMPORTED INSTANCES. fINISH SKETCH AND YOU SHOULD HAVE A NICE TOPOSURFACES WITHOUT USING THE POINTS SYSTEM OF REVIT.
29 Posts No Rating |
Thanks Moxie....I'll try that out tonight.
----------------------------------- RHL Design Group Inc. |
1 Posts No Rating |
If your surveyor topographic drawing has points with x,yand z coordinates, try this:
On the web,find a lisp function called ascpoint.lsp, run this function in Acad (Appload, then follow instructions)
This will provide you a CSV list (coma separated value)
import the list in Revit
Magic!!
pacoleonce (France)
Toposurface and ACAD files |
Tue, Nov 2, 2004 at 4:26:49 PM
A toposurface problem? |
Mon, Sep 18, 2006 at 9:16:10 AM
toposurface |
Tue, Dec 6, 2005 at 3:49:57 PM
Toposurface Outline |
Mon, Jul 8, 2013 at 1:02:11 AM
Adding a subregion to a second toposurface |
Thu, Apr 18, 2013 at 3:01:18 PM
