23 Users Online (21 Members):
Forums >> Community >> The Studio >> One for Mr Spot
Hi Mr Spot,
I have downloaded your fountain family and was wandering if you could share your water spray jpeg, i have tried using other images but they do not give a realistic appearance, my email address is geraint@pembrokedesign.co.uk,
many thanks in advance
Geraint
Umm, I created that for a uni project a few years ago. I'm not sure what material i originally used on it. There are plenty of great water materials in the Accustudio-->Water-->Liquid Library. This library is downloadable from www.accustudio.com exchange section... Just download the textures and the mlib file and load it into to revit in settings--Options HTH.
Regards,
Chris.
So you go to Settings > Options and then do you go to the rendering tab and change the AccuRender resource location to AccuStudio?
LHAA Licata Hansen Associates Architecture Reno, NV USA |
you don't change the Accurender resource loacation, you just add an additional location to look for resources. HTH
Oh ok thanks.
litle spot |
Sat, Apr 23, 2005 at 6:38:09 AM
Spot Levels [ 1 2 ] |
Wed, Nov 7, 2012 at 10:49:19 PM
18
Spot Lighting Beam Spread |
Sun, Nov 9, 2008 at 9:20:16 AM
Spot Elevation without Target |
Fri, Mar 20, 2009 at 4:57:55 PM
Spot Elevation vs. Level elevation |
Tue, Aug 19, 2025 at 1:06:15 AM
