Forums >> Revit Building >> Technical Support >> Changing Detail Sequence
Mon, Jul 31, 2006 at 2:58:24 PM | Changing Detail Sequence
Letmethinking
Setting up Callouts and placing them on Sheet which Automatically assigns Detail Numbers to them. But What if I change the Placement of Details and want the Numbers to be in Sequence. Eg. 1,2,3,4,5 in Order?
Mon, Jul 31, 2006 at 3:35:11 PM | RE: Changing Detail Sequence
erin
5 Stars: 2 Votes
Just grab the edge of the viewport, like you would to change the title, click on the detail number, and type in the new one. The only slightly annoying thing is that it won't allow you to have two of the same numbers on the page at once, so you'll have to replace one temporarily with some other value (999, 0, or anything else that won't be used).
Revision sequence
Tue, Sep 19, 2006 at 12:37:41 AM
Drawing List and drawing titleblock with sequence field
Thu, Jun 21, 2007 at 9:11:53 AM
Changing the detail level settings
Mon, Jul 27, 2015 at 11:27:45 AM
Customizing Revision Sequence Numbering
Wed, Aug 5, 2009 at 9:51:48 AM
Revit 2009 Revisions
Thu, Apr 16, 2009 at 9:04:56 PM
Page generation time: 3.4102
