15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Roofing Problems
Hi.
Does anyone know why my roof cuts at on of the sides(u have to look at the attached file) and not on the other side (it cuts on the side with the colums).
Thanks
----------------------------------- Golf anyone????? |
33 Posts No Rating |
I assume you mean that you're not wanting the roof to be cut??
If so, I would double check that your roof overhang lines are offset from the correct pitching / support point. If they're set out from different points this can cause the roof to be cut this way.
Try setting out the overhang from the beam supported by the columns, (if you havn't already done so).
GN Brisbane, Q Australia |
Thanks...
yes i did mean i dont want it to cut
Keep it up
Roofing Material Look alike |
Wed, Nov 21, 2012 at 5:35:57 PM
sloping roofing |
Wed, Mar 9, 2005 at 1:21:52 PM
Revit Roofing |
Tue, Mar 23, 2010 at 2:30:31 PM
Altering roofing structure in section views R2012 |
Thu, Jul 19, 2012 at 7:32:50 AM
Tile Roofing |
Wed, May 31, 2006 at 8:06:23 AM
