Forums >> Revit Building >> Technical Support >> column surface area
Mon, Jul 31, 2006 at 12:12:58 AM | column surface area
Bhawani
Hi' Pls let me know how to calculate surface area of the column ,also it should come in schedule.
Sun, May 14, 2017 at 11:31:54 PM | column surface area
zakazai
Did you get the answer.
I also have same problem,
if you have solution please share
Mon, May 15, 2017 at 2:34:14 PM | column surface area
archigrafix
5 Stars: 4 Votes
Assuming that you mean that a column is round, and it's not a orthogonal pillar. If you know the height and the radius you have the surface. :-)
surface=2*3.14159265 * r * h
r=radius
h=height
Edited on: Mon, May 15, 2017 at 2:34:38 PM
Edited on: Mon, May 15, 2017 at 2:37:47 PM
Marc Faber
BIM Solutions Developer
goto.archi | Oslo, Norway
Tue, May 16, 2017 at 6:30:48 AM | column surface area
zakazai
Lol.
Anyhow I got answer from another user.
the question was , how to find area of a curved or irregular surface in Revit.
Tue, May 16, 2017 at 6:33:15 AM | column surface area
zakazai
https://www.revitcity.com/forums.php?action=viewthread&thread_id=18008
area plans again?
Wed, Sep 14, 2011 at 9:07:33 AM
images are showing area surface patterns through them
Tue, Dec 10, 2013 at 3:40:41 PM
surface patter visibility in plan vs elevation
Mon, Sep 2, 2013 at 2:05:07 PM
Wall Area Schedule
Mon, Sep 19, 2011 at 3:44:22 PM
Best way of creating column casings
Fri, Aug 19, 2011 at 2:17:12 AM
Page generation time: 3.8672
