14 Users Online (12 Members):
Forums >> General Discussion >> Wishlist >> Ridge Capping
60 Posts No Rating |
(Also posted under Tips & Tricks)
I'm new to Revit, but have a reasonable knowledge of ADT. In ADT you can create a ridge capping profile (iron roof or tile), cut it in half, and apply it to each edge of a ridge and two halves form a capping (Edge profile method same as guttering but obviously not on eave/fascia edges). So far I have found Revit a much less complex program than ADT, (Revit-115MB, ADT 908MB says it all!!), but is there an easy method for creating ridge capping in Revit??
Ridge capping on angled hip ridges (15.7deg on 22.5 deg roof) and normal ridges (22.5 deg on 22.5 deg roof) has different angles etc. an it is quite complex and time consuming to create and place correctly by conventional methods in AutoCad. ADT solved this problem with edge profiles can Revit?
i agree! new user of revit but not a user of any other 3d program. love it if rooves could look better with proper flashings. can revit make sweeps on rooves?
Ridge Capping? |
Fri, Jan 27, 2017 at 6:44:05 AM
Can a sweep be applied to a roof ridge to model ridge capping?? |
Mon, Feb 4, 2008 at 11:01:27 AM
11
Ridge Capping in 2009 |
Thu, Jun 12, 2008 at 1:46:14 AM
RIDGE CAPPING?? |
Thu, Aug 24, 2006 at 7:21:01 PM
roof ridge capping |
Sat, May 20, 2006 at 11:40:53 PM
