Forums >> Revit Building >> Technical Support >> Is there a way to Beef up Section LIne weight?
Thu, Jul 27, 2006 at 3:43:28 PM | Is there a way to Beef up Section LIne weight?
oceanmandy
Does anyone know if there is a way to change the line weight of section lines? Thanks!
Thu, Jul 27, 2006 at 5:09:56 PM | RE: Is there a way to Beef up Section LIne weight?
TomDorner
4.5 Stars: 25 Votes
The line weight of the section line is under: Settings>Object Styles>Anootation Objects[tab]--Section Line
HTH
Tom
How do you adjust detail section cut line weight?
Fri, Jan 31, 2014 at 11:43:55 AM
Section Line Weights? How do you change them?
Sat, May 9, 2009 at 5:12:26 AM
Impossible to change ceiling pattern line weight
Tue, Jan 22, 2013 at 11:03:23 AM
Line weight in family doesn't equal line weight in project
Fri, May 31, 2013 at 2:54:29 PM
Changing the line weight of objects in distance.
Fri, Oct 16, 2009 at 1:01:49 PM
Page generation time: 1.4428
