27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> Crop Region not cropping all info
1 Posts No Rating |
Crop Region is cropping almost all that it's supposed to, but for some reason it's not working correctly with room tags. That is, some room tags are still appearing outside of the crop region. Any suggestions?
Crop regions will not work on annotation which is what a room tag is. (All Revit annotation is view specific)
Simply delete the room tags you don't want to appear. In 9.0 the tags do not define the room, rather just report on properties of a room so there is no danger of deleting the room if you delete the tag. In 8.1 and prior as long as you didn't delete the last room tag you would still be OK.
HTH
Tom
cropping region acting weird |
Wed, Jul 16, 2008 at 3:15:20 PM
cropping viewport on sheet is cropping my floor plan! |
Tue, May 22, 2007 at 3:51:12 PM
Views on sheets cropping eachother |
Fri, Oct 23, 2015 at 9:27:51 AM
crop region changes when placed on sheet |
Fri, Jan 9, 2015 at 3:33:07 PM
Crop region not affecting grid lines |
Tue, Oct 19, 2010 at 4:00:29 PM
