Forums >> Revit Building >> Technical Support >> new walls
Thu, Jul 27, 2006 at 12:04:16 AM | new walls
jhudtwalcker
jhudtwalcker Avatar
how can I get my new walls, in a remodelation plan, to be drawn with some kind of hatching, o something like that, so I can recognize them from the existing walls? is there something like demo plans, but with new walls?
Thu, Jul 27, 2006 at 10:30:41 AM | RE: new walls
TomDorner
4.5 Stars: 25 Votes
One method is to show the existing walls as in-filled solid with a grey tone.
To do so you need to use phases. Place the existing walls in the existing phase, then set the properties of material "Phase -existing" (settings>materials) to have a cut pattern of "solid fill" and choose a grey tone for hte solid fill. Then make sure yu view is set to Phase: New Construction with a phase filter of: Show Previous plus New. You existing walls will then be at the greytone and the new ones with no fill.
Just FYI, the material assigned to a phase is set by Setting>Phases>Graphic Overrides[tab]
HTH
Tom
Thu, Jul 27, 2006 at 2:42:19 PM | RE: new walls
jhudtwalcker
jhudtwalcker Avatar
thanks!! I'll try it...
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:42 PM
Walls
Thu, Dec 16, 2004 at 4:56:57 PM
solid walls transparent to curtain walls and railings in back..
Mon, Oct 29, 2012 at 7:34:26 AM
Foundation walls & Normal walls joint, linework tool?
Sun, Nov 1, 2009 at 12:24:18 AM
Inner walls overslaping outer walls.
Sun, Dec 14, 2014 at 4:58:35 PM
Page generation time: 0.9598
