Forums >> Revit Building >> Technical Support >> Warning for Room Seperation
Wed, Jul 26, 2006 at 5:59:12 PM | Warning for Room Seperation
CADMS
I have a drawing that I worked on a couple of months back in Revit 8. I migrated my building model into Revit 9. I am aware that the room object is a new feature. I need to add some Room Seperation boundaries. I did this before and now, each time I try this, I get a warning saying "None of the created elements are visible in Floor Plan: First Floor Plan View. You may want to check the active view, its Parameters and visibility settings, as well as any Plan Regions and its setting" I checked the Visibility Graphics and Rooms is turned on. Where do I find the rest of the settings mentioned in the Warning dialog box? What else could be the problem? Thank you.
Wed, Jul 26, 2006 at 9:32:30 PM | RE: Warning for Room Seperation
eldados
eldados Avatar
4.5 Stars: 8 Votes
type vv or vg to bring visibility/graphic... under lines make sure that "room seperation" is ticked HTH
Integrator
KarelCAD
Thu, Jul 27, 2006 at 6:30:34 PM | RE: Warning for Room Seperation
CADMS
Got it... .Thanks! This was under 'Lines' in the Visibility Graphics dialog box.
Room seperation
Fri, Dec 11, 2009 at 3:31:54 PM
room seperation lines
Mon, Mar 8, 2010 at 5:01:05 PM
Rooms - editing room seperation lines
Fri, May 16, 2008 at 5:29:29 PM
Room seperation lines
Fri, May 12, 2006 at 5:19:35 PM
Mysterious Room Seperator
Fri, Feb 3, 2012 at 2:39:06 PM
Page generation time: 0.4588
