24 Users Online (22 Members):
Forums >> Revit Building >> Technical Support >> Visibility Parameter in Room Tag
2 Posts No Rating |
Hi everyone,
I am new to revit and this forum rocks!!
I have a question regarding Room tags and not sure if this can be done,
Is it possible to add a visibility instance (yes/no) parameter to a room tag such that one can turn off the lines(rectangular box) around the room number (Just like the parameters: Show room number and Show room name)?
Because if I uncheck show room number, then the boundary/rectangle still remains which doesn't look good in plans.
I went through the family creation tutorials and have been trying to do this for a while now but not able to achieve what I am looking for,
Any help is greatly appreciated,
Thanks So much!
Yes you can add a visability parameter. When you click on the line(s) go to properties and you will see an '=' sign. Click on the = and add a new visability parameter. I've attached an example for yu to reverse engineer.
You could also take a different approach. Simply define a room tag without the lines and load it into your project. Then in a view or global basis select all the room tags and change them to the type you want. HINT: right click on a room tag and choose "select all instances" this will select every room tag of a similar type in all views. You can also select everything in a view and fitler out to only room tags.
HTH
Tom
2 Posts No Rating |
Thank you sooooooo very much!!!
1 Posts No Rating |
Can you have a instance parameter in a room tag? It seems when its a instance param its not available, only type params are available.
18 Posts No Rating |
hi guys i got a stupid box in my room tag. when i go into family its not there but when i load in to project,there it is! can anyone tell me whats wrong with my tag? also if i draw a line in my room tag family its come up with a warming saying not visible and ,same problem, when i load into drawing, she will show up
Open the family up to edit and look at your VG settings. Make sure to click the "show..." and you will see the box.
thanks heaps!
Visibility elements in a room tag |
Mon, Aug 9, 2010 at 2:58:33 PM
URL parameter in a room tag |
Thu, Feb 18, 2010 at 3:55:55 AM
Using Room Tag Family Parameters in a Celing Tag Family |
Mon, Sep 22, 2008 at 7:52:40 AM
room temperature parameter in room tag??? |
Wed, Oct 27, 2010 at 3:38:08 PM
Using a Yes/No Parameter to control the visibility of another Label in a Tag |
Wed, Feb 6, 2013 at 2:03:21 PM
