Forums >> Revit Building >> Technical Support >> Setting out walls
Mon, Sep 27, 2004 at 3:40:42 PM | Setting out walls
csp
When I set a wall a certain distance from another it always seems to take the plaster finish for where to take the dimension from and not the structure. Does anyone know how to cahnge the setting for this. Ta
Mon, Sep 27, 2004 at 9:01:08 PM | RE: Setting out walls
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
if you are speaking of temporary dimensions, this can be changed under Settings/Temporary Dimensions - under Walls, choose Centerlines. If you are talking about placed dimensions, this can be set on the taskbar when you go to place the dimension by choosing "prefer wall centerlines"
Hiroshi Jacobs
Exterior Bearing Walls?
Tue, Jan 22, 2008 at 8:46:40 AM
Flooring Tile setting out
Tue, Jun 18, 2013 at 3:59:02 AM
Halftone setting in Visibilty Graphics
Thu, Sep 29, 2011 at 9:48:08 AM
Walls in views that are set to “Shaded with edges” even though shadows are turne
Mon, Aug 11, 2008 at 9:00:45 AM
render and shadow setting
Tue, Dec 7, 2004 at 2:16:16 AM
Page generation time: 5.6872
