Forums >> Revit Building >> Technical Support >> Ceilings and Trusses are making me mad
Tue, Jul 25, 2006 at 10:22:39 AM | Ceilings and Trusses are making me mad
sashk
Okay, I think Revit makes me mad, but I will not give up on it. I like using the basic roof and leaving the structure generic, but I had to use a scissor truss in my model. I ended up using a scissor truss family and then copying each member over 24" oc. Not sure if that was the best way or not. I now want to attack 5/8" gyp bd to the bottom of it, but when I use the ceiling command, it just will not allow me to place it at any angle (pitch) is there a way to slope a ceiling? Thanks in advance
Tue, Jul 25, 2006 at 12:01:13 PM | RE: Ceilings and Trusses are making me mad
Dgodfrey
4 Stars: 4 Votes
Yes, while in sketch mode of creating your ceiling, there is a "slope arrow" command in the design bar. Once you place the arrow, select it and you can edit the properties. Pretty much self explanitory once you activate.
Sloped Ceilings & Trusses - Trusses Showing through Ceiling
Mon, Apr 8, 2013 at 7:27:47 AM
making acoustic ceilings
Thu, May 6, 2010 at 11:38:21 AM
Making Curve Ladder Trusses
Tue, Jan 16, 2018 at 8:21:53 AM
Making trusses tutorial
Tue, Dec 14, 2004 at 5:18:22 PM
adding trusses
Tue, Jun 29, 2010 at 7:14:26 AM
Page generation time: 0.3602
