Forums >> Revit Building >> Technical Support >> filled region boundry line weight?
Mon, Jul 24, 2006 at 1:50:17 AM | filled region boundry line weight?
mmetin
mmetin Avatar
how to change default filled region boundary line weight ? 1 to 3
Mon, Jul 24, 2006 at 4:50:14 PM | RE: filled region boundry line weight?
broncos4life
3.5 Stars: 11 Votes
First make sure that you have a line with the weight of 3 loaded. Then when you make your filled region select the boundary lines when you are still editing your filled region. Then just change the type of line that that is from the drop down menu. If you dont have a line with the weight of 3 you will need to load it from somewhere else or make one. Let me know if you need help making a new line type.
Tue, Jul 25, 2006 at 1:18:07 AM | RE: filled region boundry line weight?
mmetin
mmetin Avatar
thanks..
HATCH IN FILLED REGION WONT SHOW
Wed, Oct 1, 2008 at 8:59:51 PM
Line disappears under Masking/Filled Region
Mon, Jan 5, 2009 at 11:36:40 AM
Remove Model Filled Region @ Fixtures
Wed, Aug 15, 2012 at 4:19:33 PM
Line tool shortcut when in a masking/filled region..
Mon, Feb 14, 2011 at 4:00:46 AM
crop region - elevations
Fri, Oct 23, 2009 at 12:43:33 PM
Page generation time: 1.4013
