Forums >> Revit Building >> Tips & Tricks >> parametric beam
Sun, Jul 23, 2006 at 6:29:38 PM | parametric beam
dev41113
Hi, can any1 tell me how to create a beam with angular parametrics, I am able 2 give length, depth, height and thickness as parameters but not the angle ,
Sun, Jul 23, 2006 at 6:46:24 PM | RE: parametric beam
hisdirt
5 Stars: 5 Votes
You can try fixing the edge you want on on an angle to a reference plane (an extrusion edge would be easiest), then add a angular parameter to the reference plane...
beam - how to show overhead? single line
Wed, Jun 10, 2015 at 9:52:25 AM
Parametric Curved Concrete Beams
Wed, Dec 9, 2009 at 12:56:32 PM
Meeting Beam Systems to Glulam Beam
Wed, Jun 20, 2012 at 10:34:16 AM
Precast Beam System not sitting on beam
Thu, Jan 10, 2013 at 11:45:48 AM
Steel Beam to Beam Connection
Fri, Jun 18, 2010 at 1:54:36 PM
Page generation time: 2.1695
