Forums >> Revit Building >> Technical Support >> families render white. pls help
Sat, Jul 22, 2006 at 5:05:13 PM | families render white. pls help
seedy
some families I have downloaded become white when rendered. I am thinking that this is because I dont have the appropriate materials loaded. All help appreciated..I am stuck thanks
Mon, Jul 24, 2006 at 7:35:15 PM | RE: families render white. pls help
eldados
eldados Avatar
4.5 Stars: 8 Votes
just go into the family and assign materials there.
Integrator
KarelCAD
Mon, Mar 16, 2009 at 4:14:01 PM | families render white. pls help
wil9000
How do you assign materials when the family is like a block within the family? I am trying to add materials on the velux rooflights but cannot for the life of me find a way to do it? Its not like normal families where you pick an element and add a material, it doesn't give me that option?
 Appreciate any help
Thanks
 Will
Mon, Mar 16, 2009 at 4:19:48 PM | families render white. pls help
If the family was built using a cad import, you may find it under the material settings for imported objects .... settings/objectstyles/imported objects/... imports in families
Mon, Mar 16, 2009 at 4:42:46 PM | families render white. pls help
wil9000
Oh you are a Good Man, best thing i have learnt in a long while - Thankyou !!!!
White spots on render. Light issue.
Thu, Jul 30, 2015 at 1:01:48 PM
White / render
Fri, Apr 17, 2009 at 11:01:42 AM
When I render, everything appears white
Fri, Sep 9, 2011 at 8:37:26 AM
Missing objects in my render
Wed, Mar 2, 2011 at 9:34:44 AM
Help!! White spots?
Mon, Jan 19, 2015 at 1:58:00 PM
Page generation time: 0.3455
