Forums >> Revit Building >> Technical Support >> Dividing a section into equal parts
Sat, Jul 22, 2006 at 6:06:50 AM | Dividing a section into equal parts
Steiner
Dear friends Smile Can you please help me out? Let's say I have a certain section, let's a wall or just a meaningless line and I want to divide it into 3 or 4 equal parts. Is it possible? If so, How?
Sat, Jul 22, 2006 at 8:30:23 AM | RE: Dividing a section into equal parts
SteveB
3.5 Stars: 5 Votes
Draw a line perpendicular to it. Then use the array command (shortcut "AR"Winking fill in the "number" box with the quantity of divisions you wish to make. Check last.
Sat, Jul 22, 2006 at 8:55:53 AM | RE: Dividing a section into equal parts
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
You can also draw 5 lines.. one on each edge and 3 in the middle (wherever) Then just dimension all your lines and hit the 'EQ' on your dimensions. HTH
Sat, Jul 22, 2006 at 9:45:10 AM | RE: Dividing a section into equal parts
Steiner
Thank you for your help mates Smile
how to divide a line or object in equal parts?
Tue, May 14, 2019 at 5:50:58 AM
12
Dividing an external wall into different parts per floor
Fri, May 12, 2017 at 3:46:57 PM
dividing lines
Thu, Jan 15, 2009 at 11:09:19 AM
Dividing a line
Tue, Sep 4, 2007 at 9:06:00 PM
How to locate the objects in distance of "Half Equal, Equal, Equal, Half Equal"?
Tue, Jun 28, 2016 at 8:50:43 AM
Page generation time: 0.8181
