Forums >> Revit Building >> Technical Support >> Room Tagging
Fri, Jul 21, 2006 at 9:16:32 AM | Room Tagging
bi11
Hi all can anybody help me with scheduling room tags. the problem i have is that when i insert a room tag into a project and then create a schedule from these room tags it will only allow me to schedule the room areas in either square feet or square metres depending on the project standards. i work in the housing market and i really need to be able to schedule both types of areas from the one tag. at present i am having to create a seperate parameter and enter the feet in manually, which is rubbish because it doesn't update automatically thanks in advance
Sun, Jul 23, 2006 at 4:42:24 PM | RE: Room Tagging
dduarte
dduarte Avatar
3 Stars: 2 Votes
First off you're not scheduleing the room tag. In Revit 9.0 you're scheduling the room element itself. Second what I would do to schedule feet and meters in the same schedule is add a calculated value parameter with the formula... Area * (929.0304 / 10000) / 1 SF You won't get the Meters Square Suffix but you will get an automatically calculated value.
intellegent room tagging
Fri, Aug 5, 2016 at 9:26:01 AM
Room tagging open rooms
Wed, Feb 9, 2011 at 7:04:16 AM
Room Tags - Tagging Multiple Rooms as One
Tue, Feb 19, 2008 at 1:25:28 PM
Ceiling Height Tagging
Tue, May 9, 2006 at 9:49:14 AM
Tagging 2 rooms with the same tag/area
Wed, Nov 20, 2013 at 8:11:44 PM
Page generation time: 0.1441
