Forums >> Revit Building >> Technical Support >> circular chain refernce
Wed, Jul 19, 2006 at 4:02:54 PM | circular chain refernce
arch00
can anyone explain what a circular chain refernce means and how to detach it from the walls. I am drawing a building with a curtain wall system. Around the buiding at each floor is a concrete band that wraps around. as I get close to finishing the band it gives me that error. i kind of understand what it means but don't know how to remove the refernce. Thanx Gar
Wed, Jul 19, 2006 at 5:51:29 PM | RE: circular chain refernce
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sounds as though the band is constrained to something. Before editing/creating it use the unjoin tool and cut and paste it in the same place. This should hopefully remove any references/constraints that had been set. HTH
Thu, Jul 20, 2006 at 9:08:41 AM | RE: circular chain refernce
arch00
After cutting the object and trying to paste it in the same place it gives me the chain reference error, not allowing me to even paste it back in the same place. I tried to detach the wall but nothing seems to happen when I do this. Is there anything else I could remove to get this to work. Gar
Thu, Jul 20, 2006 at 9:39:01 PM | RE: circular chain refernce
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Sorry can't really help anymore without looking at the file. It may be an idea to send the file to Autodesk Support as it may be a bug... It really could be any number of things.
Fri, Jul 21, 2006 at 9:17:19 AM | RE: circular chain refernce
arch00
Thanks for your help. Will try that. Gar
Wish List - Kill Circular Chain of references
Thu, Apr 10, 2008 at 1:51:30 PM
Circular Chain of Reference
Wed, Apr 23, 2008 at 12:21:54 AM
Circular chain of refenrences (Yes, another one...)
Tue, Jun 21, 2011 at 12:35:49 PM
Circular chain of events
Mon, Sep 11, 2006 at 9:23:06 PM
There is a circular chain of references among the highlighted elements.
Tue, Aug 30, 2005 at 4:56:01 AM
Page generation time: 1.4121
