Forums >> Revit Building >> Technical Support >> Joists
Wed, Jul 19, 2006 at 9:03:51 AM | Joists
cnorrish
I work for a timber frame company and have recently started using revit. I am currently trying to draw the joists on one of our projects and was wondering why it leaves a gap between the joist and another component (see attached drawing). Is there a way so they meet each other instead of leaving a gap??
Wed, Jul 19, 2006 at 9:07:23 AM | RE: Joists
rkitect
rkitect Avatar
4 Stars: 29 Votes
Can't retrieve the image.. email it to cgibson@rdesignworks.com
Wed, Jul 19, 2006 at 11:59:37 AM | RE: Joists
rkitect
rkitect Avatar
4 Stars: 29 Votes
Looking at the image I would just say drag the end or edit the length parameter in the joist's properties to reflect how long it needs to be. Could you not copy the joists next to it that are the correct length? Or array them even? I arrayed mine when I did my framing plan (attachement) excluding the join and group option and it worked fine. HTH.
Thu, Jul 20, 2006 at 5:49:03 AM | RE: Joists
cnorrish
Thank you for your comments. The joists were done as an array but for some reason when you drag the end of the joist to meet the header it automatically snaps back and leaves a gap. I have also tried to edit the length in the properties box but the dimension is shown in a light grey colour and cannot be edited. I have the same problem when i try to put steel purlins in a project it seems to automatically snap to the middle of the wall and not the external face of the building.
Thu, Jul 20, 2006 at 7:51:54 AM | RE: Joists
latemore
latemore Avatar
3 Stars: 2 Votes
from the little i've done using structure in our projects - there are two grab handles on the ends of these element, make sure you select the right one. the dot is the bit that sets what is supporting your joist, whereas the normal double triangles set the actual end of the joist. you can also exactly set this in properties. they are great things, and we now try putting them in most projects after reading mr spot's and eldados's comments about 'building' the model. keep trying!
Sloping joists to the roof deck
Mon, Apr 4, 2016 at 11:21:15 AM
joists
Thu, Oct 11, 2007 at 4:43:14 PM
JOISTS ON BEAM DISPLAY REPRESENTATION
Fri, Dec 19, 2008 at 10:38:03 AM
Sloping Bar Joists?
Thu, May 7, 2009 at 9:41:08 AM
Adding roof bar joists on different hight brg. ends..
Fri, Oct 9, 2009 at 12:02:50 PM
Page generation time: 1.8278
