26 Users Online (24 Members):
Forums >> Revit Building >> Technical Support >> Raising an existing House
8 Posts No Rating |
I have an floor height for an existing house and I am looking at raising the house. If I change the height of the level to the new height the existing drawings move as well.... Is there any way to fix this problem??? Do I need to set the floor to the proposed level and not have heights on the existing or do the proposed as all new including the existing??
Thanks for your help
Unfortunately revit phasing does not have a relocate option for floors/roofs/etc
As such, in order to show both existing and new construciton you would need to model the floor then demolish it and recreate it on the new level...
Not much fun.
So personally i wouldn't bother and would just use text notes to nominate the levels for the existing and only use the phasing to show what elements have been demolished/created etc.
HTH.
Raising house Revit 10 |
Tue, Feb 23, 2010 at 8:52:28 AM
House raise in revit, using existing and new construction phases? |
Thu, Feb 17, 2011 at 7:07:05 AM
Raising building in Revit |
Sun, Aug 21, 2016 at 10:56:29 AM
Existing and proposed design |
Sat, Mar 4, 2006 at 5:50:54 PM
Walls set as existing not showing up in existing phase settings. |
Sat, Aug 4, 2012 at 11:21:58 AM
