Forums >> Revit Building >> Technical Support >> structural column member not selectable
Tue, Jul 18, 2006 at 7:13:18 PM | structural column member not selectable
mckdesign
I am trying to create a structural framing system of columns and floor framing and roof framing. I have loaded the aust grd 450 shs column family into the project but is only selectable in the beam mode. how can I get it selectable in the column mode? jason
Tue, Jul 18, 2006 at 9:11:29 PM | RE: structural column member not selectable
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Beams and columns are two seperate elements in revit. Sounds like the family is incorrectly labelled as being a column. The beam would need to be recreated as a structural column. HTH.
Tue, Jul 18, 2006 at 9:25:08 PM | RE: structural column member not selectable
mckdesign
thanks mr spot. i will give that a go
Wed, Jul 19, 2006 at 9:25:40 AM | RE: structural column member not selectable
mckdesign
I received some additional information about my original question and thought I would post it here for others who might have the same probelm. Edit the family, change the category (Settings: Family Category and Parameters) from Structural Framing to Structural Columns and then save it as a different family file (like grd 450 col). Load that family into the project and then try again. A good resukt all round. Jason
Wed, Jul 19, 2006 at 9:26:06 AM | RE: structural column member not selectable
rkitect
rkitect Avatar
4 Stars: 29 Votes
I replied to your thread in augi.. check it out. edit: nevermind.. that's my post quoted above =) I can see that method being a problem with Stuctural Analysis but I'm not familiar enough with how RS works so I couldn't be sure. There may neeb to be some tweaking of structural parameters in order for it to analyze correctly, so be wary of that. Post edited on 2006-07-19 09:28:13
Visibility graphics of a structural column
Mon, Aug 16, 2010 at 8:21:00 AM
Can I change Structural member hatch scale, rotation??
Thu, Jan 26, 2012 at 6:18:18 AM
Structural Column not working
Mon, Jul 2, 2018 at 10:20:09 AM
Structural link showing colored lines - please help!
Thu, Dec 2, 2010 at 3:32:36 PM
beams not snapping to beam/column
Fri, Feb 19, 2010 at 4:30:22 PM
Page generation time: 0.4536
