Forums >> Revit Building >> Technical Support >> lamp family problem
Tue, Jul 18, 2006 at 6:04:24 PM | lamp family problem
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
Hello, Can someone tell me what is wrong with this lamp that I modeled? When I place it in a thick wall like 18" it moves inside the wall. It only works in 8" or similar thick walls. This guy in the revit support has not been able to help me. I think this should be something very simple for them but the lamp I get back from him never works ???? I am very new with familes and I know I'm missing something really small Please help.. If you can send me the fixed lamp that would be great. Thanks a lot
Tue, Jul 18, 2006 at 6:56:14 PM | RE: lamp family problem
MarieCz
Hey there. I think the problem is when u use a wall-based profile for a block of any sort, the ref planes are usually from the centre of that wall - which poses a problem when u have a thicker or thinner wall (its off the wall too much, or inside the wall). The solution is to re-model the block and make it attached, via the locked dimensions or ref planes etc, from the edge of the wall, not the centre. Its that simple. Well, maybe not that simple to put into practice, if your lamp is really complex, you may have to double check all your dimensions are unlocked before you try an move the whole thing.. But if u made it, im sure u'd know where everything is. lol. Hope that helps :D
I am a-MUSE-d
Tue, Jul 18, 2006 at 9:32:53 PM | RE: lamp family problem
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Easy to fix using nested families... For future reference if you are modelling a hosted element: Add a reference plane and align and lock it to the face you wish to attach to. Then test by changing the wall thickness in the family if it adjusts correctly. Then constrain all geometry off this reference plane...
Tue, Jul 18, 2006 at 9:55:18 PM | RE: lamp family problem
amjhd
amjhd Avatar
2.5 Stars: 3 Votes
Hello, I was just about to thank Marie when I got Mr. Spot's responce I fixed my lamp by joining my geometry but Mr. Spots solution is very good. My eyes are opening now. Oh how I wish Mr. Spot was my buddy and lived next to me. lol Thank you
Problem loading custom family
Sat, Nov 27, 2010 at 7:27:09 AM
Lamp
Thu, Jul 19, 2007 at 2:53:13 PM
How to remove flashes from a solid lamp?
Wed, Apr 24, 2013 at 11:00:31 AM
Impossible to put a composant on another one
Thu, May 5, 2005 at 1:22:33 PM
Electrical fixture family
Tue, Feb 26, 2008 at 3:06:28 AM
Page generation time: 1.1079
